Discuss How many lights in a burger van...... in the UK Electrical Forum area at ElectriciansForums.net
-Matt
A coach building company I do work for built a posh "burger van" for a customer.
now I put 14 GU10 Downlights into this space which I and everyone thought was more than sufficient.
However the customer believes this is woefully insufficient, and wants an additional 25 fittings fitted! ie 49 GU10 fittings.....
At 400LM per bulb this is almost 20,000 lumens in a ----ing burger van!!
It will be 3 rows of lights, with each light 5 inches away from each other!!
Maybe I should fit halogen bulbs, and he will have some heat lamps ;)
Do you guys agree this is excessive........?
I'm guessing not much ceiling height if its in a van. Whats the beam angle on the downlights? They may be too narrow and so causing lots of shaddows in between / when the fixture is behind your head. I would have thought led battens/tubes would be better?
hay look a flying burger van ,LOL.
Reply to How many lights in a burger van...... in the UK Electrical Forum area at ElectriciansForums.net
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi all, first post so be gentle... I've recently decided to replace the MR16 50W Halogen bulbs in the bathroom with 5W LED ones. I'm aware of the...
Hi, would really appreciate some thoughts on this. Customer has asked me to change all 40 downlights in his flat (yes, 40) from ELV halogen to...
15K
I have a lounge that is poorly lit. I live in what is called a microloft building (in the UK). The ceiling is only 8 foot high. The room is about...
