Discuss How tell if GFCI or Breaker Problem? in the UK Electrical Forum area at ElectriciansForums.net
netmation
Have three (3) outlets in the kitchen that suddenly stopped working. One of the outlets is a GFCI outlet, and pressing the reset does not do anything. Also tried flipping the Breaker with no success. What most likely is the problem? Should I replace the breaker or replace the GFCI wall adapter first? Any way to tell what the problem is or is it just trial and error? Thanks for any help.
Is the GFCI Really tripped and did you push the test button and see if it trips. If not then it needs to be replaced because it won’t reset, other than that I have run into wires being loose an pulling out receptacle which takes away from the outlets down stream.
Reply to How tell if GFCI or Breaker Problem? in the UK Electrical Forum area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
A 13-year-old GFCI kitchen receptacle went bad, so I replaced it with a new one I bought from Lowe's (Eaton model TWRSGF20). After one day, this...
So I have a outlet protected by a gfci breaker, and if you use the plug test the gfci doesn't trigger . I replaced the gfci breaker and the...
I have a towel dryer on an interior wall in my bathroom, wired off the last stop in my loop of bathroom outlets. This thing has been installed...
