• Welcome to the new forum. We're now hosted on ElectriciansForums.net rather than ElectriciansForums.co.uk - Chat about the forum upgrade by CLICKING HERE
Welcome to our Electrical Forum - We started out providing electrical advice just for the UK - But now we have specific advice for the USA too! - Register for free and share American Electrical Advice.
Discuss how to cure a blowing fuse in the Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
G
Guest111
Some latvian contractors had complained about a welder blowing a fuse on an extension lead repeatedly,Finally they announced they didn't need the electrician calling out as they had resolved the issue,yes that is a piece of an M6 bolt!
Smart guys! They realised the wire was covered by the C/B so they didnt need any secondary fusing .......
G
Guest111
The laugh was the lead was a 50 foot length of 1mm flex,should have seen the overheating on it.
CockneyReject
Regular EF Member
God they could of atleast jammed an m8 in there and done a proper job
not just the euro trash that do this, plenty of fencing contractors and farmers are experts in this line of work
gnuuser
retired Industrial wire monkey
yeah they let the magic smoke out
you know when they do this type of **** they deserve the darwin awards:90:
most welder manufacturers specifically state that extension cords or leads must not be used.
K
Knobhead
Could you tell me the protection built in to US plugs and sockets?
The entire US electrical industry deserve a Darwin award.
gnuuser
actually some appliances are coming out with fused plugs and gfci.
dont get me wrong tony I agree with you and i wish we had fused type plugs like you guys use
but I have to work with what we have.
this is also the reason my home is wired for low voltage control (only outlets are at 120 volts)
all lighting and switching is at 24 volt.
also solar cells charge the battery banks for emergency lighting
the side benifit is a lot lower cost in wire
gnuuser
my statement about earning a darwin award is for those who would replace a fuse with a solid bar.
fuses are made to burn out if the current draw is exceeded this is a sacrificial safety element.
purposely bypassing a safety device be it a fuse or safety switch is just asking for problems.
K
Knobhead
Fault finding I replaced a 450A fuse with a solid link, so the back up was a 1200A ACB. After many abortive tests I’d run out of ideas. Found the fault, a tree falling over on fire gave the game away. Its roots had broken an UG joint.
I don’t recommend this normally but needs must at times.
I’ve done it a few times on 11KV (upped the protection relays first) to give a good short that could be traced. Wandering around fields in the middle of winter isn’t my idea of fun.
PS I've never work on domestic.
Status
Electrician Talk
Electrical 2 Go - Electrical Supplier and Electrical Wholesalers
Electrical Insurance
ElectriciansForums.net (formerly known as ElectriciansForums.co.uk) was setup in April 2006 to provide free electrical advice to both professional and DIY electricians. Whether seeking advice for auto electrics, trying to find electrical installation condition reports (EICR) form downloads, or whether you're here just to talk to other electricians; we've been a first-choice website for tens of thousands of sparkies for well over a decade.
