Discuss how to restore a pir zone on a system! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hello. I have an optima xm6 alarm. If i need to omit a pir zone the user guide is clear and it is easy. However, if i omit a pir zone and later wish to restore it on the system how is this done if it isn't a silly question? The user guide i have is not clear on this. Can this be done simply on the keypad?
Thank you for your help.
If you omit a zone when setting, it is only omitted till you unset the alarm. Next time you set it it will be on ( unless you omit it again).
Reply to how to restore a pir zone on a system! in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
Hello. Could anyone tell me how to remove this type of pir on an optima xm6 system. As shown in the attachment the pir has a hole underneath the...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
