Discuss How to wire a 240V 3-prong plug? in the UK Electrical Forum area at ElectriciansForums.net
you're right, but I don't know what to do with those two 120V hot wires in the plug when I have one 240V hot in the device. Any ideas?I don't think W neutro is a neutral, it has an Earth Symbol beside it. So it is likely to be for a protective Earth conductor.
Lucien, I really appreciate your answer.The receptacle picture shows what I think is the old NEMA 10-50 configuration for 120-0-120 service, once popular for dryers etc. This is now deprecated as it used a single prong for both neutral and earth, hence W (=white, neutral) and the PE symbol, i.e. TN-C with one grounded conductor all the way to the load.
The voltage would be correct with your hot wire connected to one hot prong and the neutral wire connected other hot prong as there is 240V between them, and the device would function, but there might be a safety issue if it does not have adequate switching / fusing for both wires to be hots.
Reply to How to wire a 240V 3-prong plug? in the UK Electrical Forum area at ElectriciansForums.net
