Discuss How to wire a 4 gang dimmer for track lighting in the DIY Electrical Advice area at ElectriciansForums.net
Reply to How to wire a 4 gang dimmer for track lighting in the DIY Electrical Advice area at ElectriciansForums.net
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
When a 20W LED spotlight of the same brand and design is added to a 5-meter single-wire track system, which already has four 30W LED spots...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
