Discuss I'm not sure if the Regs allowed separately bare earths. in the UK Electrical Forum area at ElectriciansForums.net
Sham, if you change the boards, I would be interested in these for the museum. They are Federal, rebadged by ECC (Electric Construction Co.) back in the day that UK switchgear makers were cloning or importing US gear. We have a lot of ECC plant but none of their boards. They were one of the four main UK makers of mercury arc rectifiers.
I used to have quite an impressive stock of both these and Dorman smith stuff and bits of the boards. I never even thought that anyone would be interested in them and chucked them 2 years ago when we moved house. I would have gladly given them away for free.
Your EICR should note all this and in this type of situation you need to pull the place apart to such an extent the only solution to resolve it is to rewire as necessary.
So really I should not stress, just give him my findings on cert, recommend rewire and leave. C2 unsatisfactory. Shall I call my scheme provider see what they say ?
Have you not something less 'stressful' to do? You are not in the game to do anyone any favours, but to carry out a business. So in a weeks time, months time, years time etc after you've installed your new CU for them, ---- happens, own us is on you. Happy days.
That new board will trip ever 5 minutes lol, this will be a can of worms for you IME
New posts
Reply to I'm not sure if the Regs allowed separately bare earths. in the UK Electrical Forum area at ElectriciansForums.net
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Now that SPD's must be fitted regardless, how does this stand from a sub-main perspective? Went to look at a job and they want a supply to a pre...
