i=p/u
Supporter
Dec 9, 2010
7,461
817
1,688
Northern Ireland
United Kingdom
In an electrical panel with feeder isolators what is there bs numbers. Ideunk
All you old looking baby's sleeping ...
a bit more info in the OP would be helpful.
Pardon
Your confused?
Reactions: 1 person
I think the O.P realises BS 7671 doesn't apply inside control panels and was asking what BS does apply
What I am saying is ,in a main panel there is feeder isolators acting as isolators for the db's. Does these isolators fall under 60947-3 ?
Yay or nay buddie. Sick the day. Your confused huh ;)
BS EN60947-3, if I've deciphered your cryptic question correctly
Maybe it is what you say , which I was thinking.. Hope you read it correctly Lucien
There is no main switch on a db within a panel, cables come off busbar too isolator , then from isolator to db.
An Isolator in a Distribution board feeding MCB's?
An Isolator in an L.V panel feeding D.B's?
Quote "BS EN 60947-3 applies to switches, disconnectors, switch-disconnectors and fusecombination units to be used in distribution circuits and motor circuits of which the rated voltage does not exceed 1 000 V a.c. or 1 500 V d.c."
Reactions: 1 person
i=p/u
Supporter
Northern Ireland
United Kingdom
In a panel
i=p/u,
snowhead,
