Discuss In a panel in the UK Electrical Forum area at ElectriciansForums.net
a bit more info in the OP would be helpful.
BS EN60947-3, if I've deciphered your cryptic question correctly
What I am saying is ,in a main panel there is feeder isolators acting as isolators for the db's. Does these isolators fall under 60947-3 ?
And, what's a 'panel' (in this context)?
An Isolator in a Distribution board feeding MCB's?
An Isolator in an L.V panel feeding D.B's?
Quote "BS EN 60947-3 applies to switches, disconnectors, switch-disconnectors and fusecombination units to be used in distribution circuits and motor circuits of which the rated voltage does not exceed 1 000 V a.c. or 1 500 V d.c."
Reply to In a panel in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am wiring a 3 prong 220 plug in a feeder panel with 12/2 wire. Should I hook the ground wire to the ground bus or to the neutral bus? The...
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
The big stately home I’ve been working in has an EMS 5096 alarm system with over 100 detectors and 3 (that I know of) panels. All detectors are...
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
