Discuss Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
i meant a guy. not a guy named Guy.Just a tiny point, but as a proper noun, maybe a capital "G", Tel?
Gestapo should have a capital G. it's/was an organisation and as such deserves it. like Spetznaz or Messserschmitnot guy, gestapo!
So what would a 4 pole isolator do then?Have you a copy of BS7671?
Still no, the circuit needs 1 overall point of isolation, which if you're taking it from 3 different CU's it obviously can't have.
Notifiable work only if I tell someone.By the looks of it you’ve got 10 circuits spread over 3 boards?......(you could probably do the lot on one board realistically if you did some calculations) why not just re-jig them slightly and feed the hob from 1 new rcbo.....50a if you feel the need but I doubt you’ll need it.
But bare in mind it is notifiable work so you’ll need a spark in a scheme
isolate 4 poles???So what would a 4 pole isolator do then?
[automerge]1567091249[/automerge]
Most of the people on this site like to do the job properly Bogart, including notifying jobs when they need notifying. You mentioned earlier you were 'going around in circles' when discussing this on another site. I think that's probably because you have a set idea of what you want and don't seem able to budge too much from that, even with the plethora of opposing arguments from experienced and capable electricians.So what would a 4 pole isolator do then?
This is a very very bad idea. Please do not do this.And one more question . Is there anything to stop me running the hob in 3 phase even though I have 3 CU each on a different phase? I was intending having a 20 Amp MCB in each for the hob. The hob is split into 3 zones so I
assumed, rightly or wrongly , that this was permissible.
or buy a gas hob, thus taking thread over to a gas safe forum. .Get an Electrician in to do the job.
If I cut a piece of cable and then just join it together by twisting the conductors together will it work?So 4 pole RCBO fed from the henley blocks with 4 pole isolator by the hob. A simple yes or no will suffice.
It’s a simple no then.So 4 pole RCBO fed from the henley blocks with 4 pole isolator by the hob. A simple yes or no will suffice.
close the door on your way out. DON'T SLAM IT. .Will give up as seems impossible for you lot to give a sensible answer. Why did I bother?
Reply to Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
