Discuss Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
Will give up as seems impossible for you lot to give a sensible answer. Why did I bother?
You’ve had the sensible answers but you just won’t listen to them.
and he's got to buy a new dummy. he left his on the floor.
Stick your tongue out as much as you like. Probably sums up your mentality!
[automerge]1567194665[/automerge]
Still waiting for one.
[automerge]1567194693[/automerge]
Moron with a moronic reply.
[automerge]1567194748[/automerge]
Goodbye!
flattery will get you nowhere.
Thread now closed as it’s clear that @Bogart isn’t willing to listen to the advice given.
Reply to Induction hob. in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hello hope you can help I have a single oven 2.4kw max and a ceramic hob 6kw max I would like to put then both on the same circuit so i was...
hi looking to install a new induction hob to current wiring . the wiring i have is thick white probably about 15mm wide and is hard wired into...
Hi all, I’m now ready to install my hob, I have a 32A MCB with 6mm T&E feeding a 50A rated switched supply at the worktop. The hob isn’t supplied...
About 5 years ago during a full refurb on my house I re-wired the property myself (old aluminium wiring) in line with 17th edition. I had it all...
