Discuss industrial heaters in the Industrial Electricians' Talk area at ElectriciansForums.net
Evening All,
can anyone advise of the best means of electrically heating an a large area 50x30ft, containing electrical control panels , the aim to prevent any moisture ingressing the electrical equipment( motor pumps etc.
Are you thinking about heating the entire area? You could end up with a hole in the ozone layer named after you :) Why not just use a small DIN mounted heater in each panel.
Gas? Bonkers to heat an area like this electrically.
Problem with gas is that H2O is produced as a by product of combustion so it's likely to increase the relative humidity as well as warm up the space. As soon as the temperature drops again to ambient there will be condensation everywhere.
Of course. i was thinking of the high bay heaters used in garages etc..
I've not come across the heaters you mentioned, I will have a look now.
TBH it's why I posted my second opinion on the problem.
I’ve got to agree with Marvo, install local panel heaters. But be sure to ventilate the panels otherwise the panels will be wet through.
I don't think i've seen any switchboards, MDB's or other electrical panels of any consequence not to be spec'd and provided with panel heaters. All run through a thermostat to ensure the enclosure doesn't drop below a preset temperature!! Can't ever remember having to retrofit a panel heating system before, but then i guess i wouldn't expect to, on the sort of projects i work on...
For that size, if you have gas, fit a warm air heater that has flue to outside, you have to use a flue on those anyway, then all the water vapour goes outside. Plugs and Sparks Ltd does a good line in these heaters if anyone is interested.. :)
Evening All,
Are these panels actually live and working or are they just sat there in storage? The way I read it was the latter, usually the control transformers,vsd's, reactors etc keep the panels warm and the same goes for motors and pumps if running.
Reply to industrial heaters in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
How would you go about this realistically, the office is open plan and about 15m x 7M, grid ceiling with loft space above, windows and insulation...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
