Discuss install rosy lights-switch and connect in the box,I have a problem with o in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone
I hope you all well,,
I have a question regarding old method install rosy lights-switch and connect in the box,I have a problem with one fault sort it ,the light doesn’t work,I needed help,I have experi connect in the switch…
I take it it’s a problem with loop in at the ceiling rose. 3 plate, or whatever you want to call it.
(Correct me if I’m wrong, or this thread is heading off at a tangent)
It’s easy using loop-in to get things mixed up when the black (now blue) from the switch is live rather than a neutral. It should have been sleeved.
Is this a new fault in existing wiring, or were you working on the circuit and created the fault?
Best advice just now is pictures.
Reply to install rosy lights-switch and connect in the box,I have a problem with o in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
