- Mar 21, 2011
- 13,191
- 11,409
- 18,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Retired Electrician
I had a job today relocating the electrical supply for a power shower in a ensuite bathroom, to the airing cupboard where the new shower pump is now located. The FCU for the supply was already located in the airing cupboard, so the existing cable was long enough, I just added a flex outlet plate to connect up the new shower pump. I carried out the normal dead tests/live tests, but I was unable to successfully carry out the IR tests, as the FCU has been previously fed via another FCU/RCD. This feeds another shower pump in the main bathroom, which eventually will be removed. When I return to remove the old bathroom supply, and probably the FCU/RCD (the CU has a RCD main switch), I will retest the IR.
However, this has got me thinking. In the past, for smaller jobs, replacing luminaires or replacing an odd socket, I haven't carried out any tests, other than perhaps to do Zs or RCD test. Having subbied for other sparks/companies, I've not been asked to provide any test results, for some alterations & additions. I know what the regs says, but I just wonder what others do, in terms of tests. Now am I doing too much or too little, for example, the installation I gave in my first paragraph, or other examples you wish to describe.
