Discuss IPx what? in the UK Electrical Forum area at ElectriciansForums.net
Dave Appleby
Ok. Fun Monday one.
Can someone tell me the IP rating of a Debenhams bag?
Should I be using M&S or for top protection a Harrods one?
I would guess around IP24
as long as it has been well tied round the item being protected.
for outdoor equipment, I would prefer to see a black bag as the carbon helps with the uv protection to a limited degree.
Unfortunately, I dont believe the retailers list how well there bags perform as weather protection and although there may be some merit in using a bag from a high cost shop, it has yet to be independently verified.
Some of the supermarket bags are biodegradable, so nit really ideal.
A friend tells me the small pink ones from Anne Summers are pretty waterproof though...
Pah, amatuers. They didn't seal it with cheap insulation tape.
Reminds me of when i used to work at the Dundee flower and food festival. The stallholders would rent their little pitch for their garden displays, and ask for a double socket if they needed one. So they were left their little plot of land and a socket on a wooden stake.
I get an emergency call, power off in half a dozen stalls.
Go and find someone that had plugged in their little lights and water features, covered the socket in a black bag, and then dumped a tonne of topsoil over it to create their "masterpiece" on.
Its not just about waterproofing it... its heat disapation as well
I've just tried CEF, Screwfix and Stoolstation and none have them in stock. Is there a short term workaround ?
Reply to IPx what? in the UK Electrical Forum area at ElectriciansForums.net
Hi, Buying a replacement extractor fan. It falls into zone one with the room setup. Looking at two fans. One is rated zone 1 one is rated zone 2...
Evening all, I'm relatively new to the trade and have just moved house. Looking to rewire and was looking at a few things, could someone tell me...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
