Discuss Is it okay to have a light switch and SEPARATE dimmer on single lighting cct? in the DIY Electrical Advice area at ElectriciansForums.net
Is this a common requirement for a dimmable light switch?...
I know there's push on/off dimmer switches, but it seems inevitable to me that the dimmer setting changes a little (i.e. the knob rotates a bit) whenever it's switched on/off.
I want the lighting level to be controllable (i.e. dimmable) occasionally, but for the great majority of the time I want it left precisely as it is! I certianly do not want a dimmer that 'switches on at the start of its rotation, and then steadily increases in brightness', because that would necessitate carefully adjusting it every single time!
So, what I think I want is a normal (on/off) light switch mounted adjacently and in series with a dimmer.
Does that make sense? Is it a reasonable/common requirement?
Thanks for any help or advice.
Yes you could fit a two gang grid switch which has a dimmer module and a standard switch. Supply to standard switch first then into the dimmer. Bare in mind the dimmer switch will only function with the standard switch on. Set the dimmer then use the standard switch for on and off.
I have a lightwaverf smart switch.
It has 2 buttons for on an off, but if you press and hold one of them it dims up or down until you release.
Then next time you turn it on, it only lights up to the dim level that was set, not fully ā€œonā€
Reply to Is it okay to have a light switch and SEPARATE dimmer on single lighting cct? in the DIY Electrical Advice area at ElectriciansForums.net
I have a single wall switch powering 1 light and I want to add a separate light and change to wall switch to a double to power them both...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
The G4 110V 3W dimmable bulbs I purchased work with a dimmer. I can brighten them and dim them, but when I turn the dimmer off, the LED bulbs...
Hi all, I am upgrading my traditional 2 gang light switch in the kitchen to a smart 2 gang dimmer switch. When I wired up the switch the switch...
