Search the forum,
Discuss Is there a chance Dual RCD Consumers could be "banned " from rentals soon? in the UK Electrical Forum area at ElectriciansForums.net
You mean switching the line ?
That's all that's needed
If there is little risk of a "hot" neutral then that is true. You get the full isolation for testing and selectivity with any up-stream RCD protection for N-E faults.
However, if you do get a hot N situation then you rely on the RCD action for tripping, and that is far slower than the usual magnetic part of the MCB side of things. Also most SP+N type devices only have the arc-chute in the L side so a high energy N current fault might total the device, etc.
In the UK it generally will do yes. But in another country where supply polarity cannot be guaranteed or where neither pole of the supply may he reliably connected to earth then the difference should be obvious.
I'm not intimately familiar with conventions of electricity supplies in other countries. It's easy to forget that polarity is of less importance in other parts of the world and that reliable earth connections often aren't considered to be of as much importance as perhaps they ought to be.
New posts
Reply to Is there a chance Dual RCD Consumers could be "banned " from rentals soon? in the UK Electrical Forum area at ElectriciansForums.net
Long time lurker so this may be my first question. I am a qualified electrical engineer, but in aeronautics not domestic installations, and I may...
9K
Ok first and foremost I’m not a sparkie, I did all the work in my own house 30+ years ago, which a sparkie checked and approved and I know the...
5K
C
Hello there i wonder if anyone could offer any advice on a problem I am having: Although not a qualified electrician, I recently swapped out the...
6K
chelwood
C
Ok, so I'm registered with Rated People. I don't use them very often but once or twice I have purchased a lead that has turned out to be very...
