Search the forum,
Discuss Is this dangerous? in the Australia area at ElectriciansForums.net
T
truescot
Looking for a simple bit of advice.I want to put up a coat rail in our small entrance hall. The only place it can go would mean that the bottom of the coats would cover the fusebox/consumer unit (has MEMERA 21 written on it). My wife is worried that this is a fire hazard. Is she right and this should be avoided?
No its not dangerous, you still have access if required. Mine is in the hall cupboard with the shopping bags etc etc. The consumer unit is safe within its own enclosure& Providing it has a cover over the fuses / mcb's you cant make it any safer. You will find many under stairs or in similar positions.If theirs going to be a fire your coats arn't going to stop it or make it worse. piccollo
Indeed, i would probably think about putting the rail elsewhere.
Cables could very well be buried in the wall above the consumer unit, plus what has also been pointed out, that wet coats above could also be a hazard.
I have had to empty whole cupboards to get even close to the Fuse box in some houses, so I wouldn't worry about it too much. As someone said, so long as they arn't wet...
If it really has to go there then as the guys have said, no wet coats! Only thing I would add that there is a 90% chance that cables will be present there so get the gripfill out !
Reply to Is this dangerous? in the Australia area at ElectriciansForums.net
The purpose of this thread is two-fold: to let you folks see an EICR from someone who's too lazy (or busy) to even bother forging his test...
4K
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
One of the oddest jobs I've ever had today. Called by a plumber I know who had attended after a leak through the kitchen ceiling from bathroom...
6K
Im seeking advice from a job we have done with the most difficult customer of my whole career. We're a family business of 50+ years and take pride...
11K
