Discuss Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
I
Went to isolate light & found this.
This has been rectified.
What further action would you take?
As Pete said is it an em light, seen lots of modular fittings with em packs which have been given dual supplies.
Thats a clix type connector (basically a means of isolation of the light by separation of the supply) can you elaborate as to how it was live ?
The emergency ones are usually coloured red and basicaly are a plug and socket used to isolate the supply. thats the male end it should never be live once unplugged. It is like putting a standard 13A plug on to a live cable so if anyone touches the pins they recieve a shock.
basically its a ceiling rose that you can unplug the light from.
They normally are red but I have seen modular fittings connected across two circuits, one for the charge supply the other for the normal supply.
Best turn that circuit off , Someones probable daisy chained the lights and put a click rose at each end of the circuit , or as other have said there could be a permanent live coming from an emergency light supply budged into the light fitting
So in answer to your pole:
No it's not safe to work on, and 2 how do we know anyone should be held to account?
It's been signed off by an Niceic member, so must comply to standards, so should be safe to work on.
This could be their normal standard of work & the same may exist in another building.
Somebody must be accountable.
Plugs & sockets, are listed as methods of safe Isolation.
I go to isolate & find live ends that can be touched, which could easily of come into contact with the ceiling grid.
I could if been thrown off my ladder, injured & electrocuted.
Very close to a Reportable Incident under Riddor, ie legally obliged to report to the HSE!
Bit like metal CUs, lighting circuits seem to blow people's minds. Had a similar incident a few years back now when doing PAT, the manager of the shop had linked two banks of sockets together at the counter using a flex with a plug at both ends. Yep I got a belt and the manager nearly did, you were lucky.
If you have 239Volts lingering around it can't be safe to work on, isolate all supplies, if it is an EM fitting and has been wired as some suggest, then it could be thats how it was wired in the first place, if what you say is true and it has been passed by NICEIC, then look no further.Remember dangerous occurrences have to be specified under RIDDOR
I had the same thing when we had to PA test a load of stuff at the German Market in Birmingham they had put a European plug on both end of a flex to power some 4 way power blocks , I smashed half the display trying to let go of it !!!
Reply to Isolate Light to find Live Plug in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
