Discuss Jubilee line light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi
I Recently purchased a Jubilee Line button from the London Transport museum. I was looking to convert this to a light switch. Can one point me in the right direction ? I would be looking to employ an electrical to connect this but wanted to know whether it was possible etc
It's likely that isn't mains rated and is probably a momentary switch, in other words it doesn't remain switched once released.
It could be mains rated but the switching function is not suitable for a light switch without peripheral parts but yes it would suit a door bell.
Would require an enclosure for a relay to latch on and then off.
12v circuit switching a 240v through a contractor.
Fairly simple operation, but was that button “bought from a museum” or obtained off the side of a train during an especially drunken weekend.
Bought from the museum...
I was thinking of a push button mechanism behind the button. Are you saying you can do this in a more sophisticated manner?
Are you a train spotter?
You could easily wire the contacts of the button into an rf unit that then activates anything you want it to
I am not!
Does anyone that is based in London have any interest in helping me with this project?
Ok, I was just asking out of interest.
In the Isle of Man trains are very popular with many enthusiasts.
The task is a very simple one.
Would probably take 1 to 2 hours.
Plus approx ÂŁ100 to ÂŁ150
The button is a momentary switch, on when you push it, off when you release.
You need a latching relay that will stay on... then another to release the latch by pressing the same button I assume?
You get the 12v or whatever circuit working first, then use it to operate a 240v circuit with a 12v coil.
There may be ready made solutions from cpc farnell or RS websites
Forgive me I have no experience of converting a device like this. Are you suggesting I go into a local branch of RS or contact a local electrician?
What does the light switch control that you are wanting to convert?
Downlights?
Reply to Jubilee line light switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I have a single light switch, wired like this.. the 2 wires in com, with a always live wire coming to the switch, and then wire going out to...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
