Discuss junction box in the UK Electrical Forum area at ElectriciansForums.net
any recommendations on a box to join 10mm t&e to two 2.5 s.
basically 10mm is supply cable and 2.5 will be lollypop ring.
was thinking of a duel appliance plate unless anyone can think of something better.
cheers
Nick
anythng that can handle the current, cable sizes, and is compliant will do.you could get 1 x 10mm an 2 x 2.5mm into a single cooker outlet box. are you consicerting fusing down at this point?
Sometimes you see that arrangement with a 32A or 45A isolator switch joining the feed to the ring, say for a lab or classroom.
Or use something like the 60A junction boxes that have the double screws for less trouble longer term:
https://www.cef.co.uk/catalogue/products/184449-60a-junction-box-3-terminal-white
They are not maintenance free though, so still need to be accessible behind a cover or similar. Off hand don't think I have seen a MF box for 10mm cable.
It’s only 30 quid for an mcg garage board...
Incoming rcd with a 16 and 6 MCBs.
No hassle at all.
lollipop rings are unconventional, and may be confusing to future works.
Reply to junction box in the UK Electrical Forum area at ElectriciansForums.net
I found a 13A FCU, connected to the kitchen ring supplying an outdoor junction box, providing two SWA 2.5mm radials. Unconventional? yes. One...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
