O
Octopus
What ever you decide just don't have the plugs for the appliances behind the appliances ....
Discuss Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
Never a socket behind an integrated appliance, but a trailing socket on the other hand is fine. Gives a lot of flexibility in the installation as well.What ever you decide just don't have the plugs for the appliances behind the appliances ....
Thanks for the reply.... all the grid set ups seem to be the norm in new builds these days. Plenty of call outs then if that's a common occurrence then!lost count of the number of burnt out grid switches i've seen. some just defunct, some bridged out due to failure. only ever fitted 1 4 gang grid for kitchen appliances. bit me in the arse when the freezer switch failed and customer hit me with a £300 bill for ruined food. never again on my watch.
Not sure about that one... why without sounding rude?Never a socket behind an integrated appliance, but a trailing socket on the other hand is fine. Gives a lot of flexibility in the installation as well.
Just to add if there's a problem with an appliance... it has to come out regardless of where the plug in point is anyway.Not sure about that one... why without sounding rude?
I've heard of quick flow connectors on appliances that have had there plugs cut off? A bit like the flex outlet method of old which I never liked.
Do you have the grid on show?Use grids all the time never had a problem with them Either 4 gang 3 or 2.
They are a particular favourite of most of the house builders and are specified on the drawings for the kitchen layout.
Not sure why it’s a problem putting a socket behind an appliance either as is the norm with new builds our company carry out and I’m unaware of any problems while doing this.
If the appliances are tight tho then the appliance fitter will advise and we fit an a unswitched fused spur with flex outlet but always behind the appliance which is controlled by a DP switch in a grid set up.
A little far awayAgainst the ceiling in the downstairs toilet, a few metres from the kitchen.
Lets hear your preferred method?
Reply to Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
