P
paulsayer81
Hi guys - would really appreciate some advice here...
My Mrs has brought some bedside lamps home from the US which she wants to use at home in the UK.
The lamp holder is rated 600w 250v, so I'm assuming this means the lamp holder is ok with UK voltage, however, it's obviously got a 2 prong US plug on it and the cable is 2 core. The lamp holder itself is metal (brass) with a switch on the lamp holder itself, the rest of the lamp is glass.
Does the lamp holder need to be replaced with one that is earthed and the cable replaced with 3 core, or is it ok to put a UK plug on without wiring the earth pin on the plug?
Thank you!
Paul
Thank you!
Paul
