Discuss Large builders in the UK Electrical Forum area at ElectriciansForums.net
Without getting drawn in to ‘how quick can you lash out a new build’...
1st fix basic spec house.
On your own you could probably chop all the boxes in one day and start drilling out joists. Day two finishing drilling the joist holes then start pulling cables. Day three full on cable pulling day. Day four finish off wiring and do all your capping and tidy up any odd bits.
Day five if necessary
Totally agree,same procedure I had,many years ago.
No chopping in boxes as dot and dad so 25mm boxes are used only ones to be chopped in are 35 & 47mm for the grid, cooker and shaver sockets.
All the large housebuilders use I beams with the webbing or have the knock out holes if need drilling they are only thin ply type wood.
Most new builds these days are fast fix boxes , fine for switches but after a few months of pulling plug tops in / out from 13a sockets they start to break the plaster around the wings.
Then looks dog rough
I was helping out a friend back end of last year to get some new builds done before christmas on a labour only basis. Only 8 houses.
He had previously worked for a large contractor who do a lot of the new build developments around here before going solo.
They typically would first fix a standard 3 bed house in 4 days. Second fix and testing for certification taking another 2 or 3 depending on spec.
They didnt see point in rushing normally because they were usually on a price per house rate depending on size, and there was always a week allocated for the electricians in the schedule, so they could take upto 5 days for first fix before the other trades got held up. they had another 3 or 4 allocated for the 2nd fix. So always had capacity for slight over runs
With some builders they plan out the job poorly and things are always being moved around. it often shows in the final finish of things like skirting and decoration within the property as the customer doesnt see the wiring.
I've never ever had any problems like that with dry lining boxes, always use Appleby, maybe the different lug design helps avoid such issues ?
up until recently a lot of the social housing built by the large developers around here had just lining paper on the plaster boards then a quick splash of emulsion. saved a few hundred on each property, they were built to bare acceptable standard as part of the planning requirements. has been some improvement of late with the air flow tests amongst other things requiring things to be sealed up well.
The last big Barrett site I worked on was just taped joints and filled/painted. Not a drop of skim plaster touched a single wall.
But other sites I previously worked on got a skim of plaster
Reply to Large builders in the UK Electrical Forum area at ElectriciansForums.net
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
I've come to a decision, I just cant do work anymore that involves mad stuff, for example today - 2 bed flat that's had fire damage, someone has...
