Discuss LED bulbs Dim glow!!!! in the Australia area at ElectriciansForums.net
I had this problem on a kitchen lighting circuit.
i fitted a 400v 0.1uf capcitor across the switchline and neutral at the light fitting problem solved for me.
worth a go £2.87 from maplins.
Ouch! 2x160k Ohm, 0.6W, resistors 26p each from Maplin, cheaper 1/4W types available elsewhere.
Thanks for that. Some really good technical advice. What would I do if there is 6 effected down lights that are dimly glowing? (on the same 3 way switch) Sorry if that sounds thick!
The solution is cheap enough that you can afford to do all 6 lamps if necessary, but normally you'll have to do less than half of them. Do a lamp at a time, functional test after each modification, until the problem disappears. I would choose the last lamp on the final circuit, then if required a lamp near the middle of the circuit and if required then the first lamp on the circuit, etc. Usually I find one pair of resistors is all that is required.
a snubber is, afaik, a combination resistor/capacitor which is wired L/N or SL/N, as said above, trial and error as to where and how many you have to fit.
merloy99, in the UK a 3 way switch is a 2 way???? EH 3 way switching is not 2 way. Im not american at all. 3 way switching includes an intermediate switch.
Your phrasing is a new one on me mate!
Reply to LED bulbs Dim glow!!!! in the Australia area at ElectriciansForums.net
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Evening guys! I have three of these bulbs on a ceiling light, controlled by a dimmer switch installed by an electrician...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
