Discuss LED DRIVER PROBLEMS in the Lighting Forum area at ElectriciansForums.net
Hi guys went up the loft to smell burning coming from the led down lighters and found the old ring saftey transformer melted, ordered new AURORA 12V 1-25W LED DRIVER, every time i try wiring it up the bulbs are very faint, when i probe the driver im getting 240v but nothing coming out also light seems to pulse sometimes, anyone have any ideas plz would be appreciated thanks.
The black one is the old one that was burnt nd the box is the new one i bought from screw fix.
That us the wrong thing you need a 12v transformer 20-60va for halogen lamps the one you have bought is an LED driver it is incorrect.
Reply to LED DRIVER PROBLEMS in the Lighting Forum area at ElectriciansForums.net
I have an old IKEA Norrsken 12v suspended ceiling tension wire system, which runs x7 20w MR16 bulbs, from a Min 4x20w/Max 10x20w transformer. Can...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
Hi I have a 3phase shop in a high humidity area in (Hawaii) and I'm having some issues with low voltage on the single phase outlets on the 120v...
Hi guys (can I assume pronouns?!?!?!!), I’m in need of a certain LED driver for the attached LED lights. The problem I have is that I’ve wired...
