Discuss LED Strip lighting behind bed frame. in the Lighting Forum area at ElectriciansForums.net
Hi everyone,
I'm looking to put some LED strip lighting behind my bed (after redecorating). I have installed some warm white downlights in ceiling but want a small amount of mood lighting.
The strip light is coming from a fused spur, into the driver and then to the strip light. The only problem is, is i do not know a good quality product that will work well because i want it to dim down via RF or from my phone. It also needs to be a warm temperature, i am not bothered about colour changing.
If anyone has some solutions for this, expensive and budget, i would be grateful. I just need to know i am buying a quality product where the dimmer will work with the light strip and driver, the driver works with the dimmer and so on.
Thanks for any help.
Reply to LED Strip lighting behind bed frame. in the Lighting Forum area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
