Discuss LED Strip lighting in the DIY Electrical Advice area at ElectriciansForums.net
Maroochy
I have installed LED strip lighting behind some landscape panels. There are 7 panels each panel having 2 x 1200mm 2538 LED light strips. I have two power feed lines - one powering the furthest 3 panels, one powering the closest 4 panels to the power source. The power source is a 22amp 320 watt LED driver. I tested the system with a battery - all lights worked. Hooked up the LED driver - all lights worked - initially. Now the 3 string doesn’t. What is the likely cause?
TL;DR
LED Trouble
My suspicion is a bad connection in the wiring.
I've had problems with the connectors on the ends of strip lights. My symptoms were similar to yours. Soldering is reliable, but the clamp-on connectors can be flaky, even from good brands.
Reply to LED Strip lighting in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
