Discuss Light switch in the The Welcome Forum area at ElectriciansForums.net
T
tgoss
Hello everyone,
I want to build a lamp with 2 different light bulbs. There can only be one light bulb switched on because otherwise the driver will become way too hot. So I want to make a switch that immediately switch a light bulb off when the other one is switched on. As you can see I don't know much about electronics ... And my mothertongue isn't English so I did my best to write this without mistakes.
Thanks a lot!!!
Kind Regards, TG
Standard 2 way switch will do the job. Feed in and 2 switch wires out :)
what voltage are the LEDs? if they are 12V D.C., a normal 2 way switch may not suit. assuming the driver output is 12V, you need a 3 position, centre common, switch with ON1 or ON2.
never seen 230V LEDs with a separate driver.
Thinking again a 2 way won't give an off position.
Oh OK! I figured it out :) I've solved the problem. A massive thanks to everyone for the answers on my question! Thanks! Tgoss
I'm going to do everything manually. I wanted to have everything automatic but I think that's a bridge too far for now.
The switch tel mentions in #5 will work.
on-off-on-diagram (1).giffeed to 2( centre). lamp 1 to 3 . lamp 2 to 1
Reply to Light switch in the The Welcome Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
