Discuss Lighting switched line in another light's enclosure in the Australia area at ElectriciansForums.net
Richard Burns
Mentor
I had a job to replace downlights with fluorescent battens, however when I came to the job they wanted the downlights to stay as well, this meant a large increase in the job requirement supplying new wiring for the fluorescents.
I wired this is such a way that the switched line for the downlights is now junctioned in the fluorescent enclosure (using the space as a junction box). I therefore have another live supply (joined with a wago and labelled up and positioned well away from the Fluorescent terminal block) inside the fluorescent enclosure.
Is this acceptable practice and does it break any regulations? If you could supply guidance I would be grateful.
The other ways to supply power would be running another cable 10m back to the CU through a very full loft or having a separate junction box in the loft.
Just to clarify how I wired it (or perhaps just to confuse!)
I replaced the local (two way) switch with a new two gang switch, linked the permanent line to the fluorescent switch and took the new switched line up to the fluorescent.
I then removed the SL N and E cable from the first downlight and brought it to the flourescent enclosure to supply N and E into the fluorescent and then used a new T&E to take SL(downlight),N and E back to the downlight. There being no space at the downlight to have three cables.
Thank you
Hi Richard, What you have done is fine and don't appear to have infringed any wiring regulations. This effectively a loop-in at the fluorescent fitting, using the enclosure to house your wago(s)/terminal block(s).
Reply to Lighting switched line in another light's enclosure in the Australia area at ElectriciansForums.net
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
