R
Roger
Evening All,
I have 2 Channel Scimitar panels 8 and 4 zone serving two factory units approx 70 metres apart.They need to be linked .I have a spare zone on the 4 panel one ,do i use that as a input into my 8 panel one ?
I have auxiliary inputs and outputs on both panels,what goes where ?
Auxiliary fire output on larger 8 panels to class change input on smaller panel.
Advice welcome or local expert in the south east area please.
Also unit is inside factory which is obviously locked and not easily accessable out of hours,should panel be located in an enclosure on the outside so the services will be able to find it in the event of a alarm being activated.
Saw one on the outside of the shop in the middle of the high street the other day behind a glass cover so at least it could be seen by the services,compliance ?
Life's a education and it seems i have a long way to go sometimes !
