Discuss Low voltage reading on OFF circuit in the UK Electrical Forum area at ElectriciansForums.net
harry3
EF
On standard residential house wiring (USA).
Working on a single circuit with the circuit breaker in OFF position at the wall.
When connecting a decent (Klein) multi-meter to black and neutral (white) wires I see a low voltage reading of .4260 (POINT four two six zero) showing on the multi-meter screen.
Does this reading mean something is wrong? Or can any one explain why I would see the low voltage reading when circuit is OFF?
digital meters will give silly readings like this. you can even get similar without the leads connected to anything. nothing to worry about.
More than likely just a little induced voltage from another circuit.
Harry You have a multi function meter and if you had the power on and you read point .4260 it sounds to me like you have your meter on the wrong setting or you have tamper resistance receptacles
Harry I miss read that you have the power off and your meter is probably fluxulating. It’s reading millivolts you have no problem with your meter
Reply to Low voltage reading on OFF circuit in the UK Electrical Forum area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I'd like to wire a six pin DPDT rocker toggle switch to turn a low voltage LED fixture on and off. The rocker toggle switch I have is an...
