Discuss main bonding with plastic pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rob69
I have got a refurb to rewire, the incoming water supply is in plastic pipe as is all pipework
in the premises run in walls and underfloor.Copper is only used to connect to radiators and taps
where they exit the wall or come up from floor boards.
I can therefore omit the main bonding as long as disconnection time is met!
Is there anything else i need to take into consideration and what about supplementary bonding in this situation????
Thanks for any assistance you give!!!!!!!
forget about bonding. full stop. ( unless there's gas , of course. you'll need to bond that)
It doesn't hurt to run a bonding cable to the stop cock and coil it, that way when Mickey Mouse and his friends eat through the plastic, and its been replaced with copper, the bonding cable is sitting there waiting!
In fact locally the plumbers tend to put in about a foot of copper after the stop cock so it can be bonded. That sounded a bit like a compliment to a water devil so I'll back it up with, they've probably dreamt up a regulation about it like they dream up all the others!
Reply to main bonding with plastic pipes in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Did a eicr on a upstairs flat, there is 1 main bonding cable from the consumer unit, the gas pipe comes from the gas meter outside and up the wall...
Good afternoon one and all. I, like many non-electricians are having issues regarding the need to have domestic water pipes (plastic entry to the...
5K
Good morning everyone. I’m looking at getting an EV charger installed at my home and the company is requesting that I earth bond my water supply...
4K
