Discuss MCA High Voltage Courses in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
No but I have done HV switching courses at: RAF Cardington, Schneider and several other establishments, RAF Cardington I believe was the best, but sadly no longer exists
oops ignore my last comment. Didn't notice my dyslexic typing was back.
i meant of course Training
I've edited your opening post and corrected the spelling mistake for you and deleted your other post for obvious reasons.
Reply to MCA High Voltage Courses in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi Guys, I'm looking at booking myself on the 2391. Just wanted to see if anyone has ever done the course online and then done the 2 day exam. If...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
Hi Guys, looking at doing Initial and Periodic inspecting and testing. Looking between the CandG and EAL Just wondering if I can ask peoples...
Hi guys. Having a weird problem in a house that has suddenly happened. One half of the ring main has 240ish volts (fluctuates of course), and...
