davy d
Hello
Quick question.I know the Megger 1502 is an old model now and they are a bit cheaper to buy on fleabay but are they up to the job ? I don't really need the blue tooth function of the new ones and am wondering would the 1502 do to get me started.
Davy d
I use a 1502 and it's brilliant, the only down side is it doesn't have the automatic rcd so if you are on your own you do have to walk back and forth to db.
does the 1502 have ramp test?
Not if you test the RCD at the board, and tested at the board you don't have to go round unplugging appliances.
C
Australia
cthomson07
C
C
  • Question Question
C
megger mft 1502
Australia
davy d,
dim_bulb,
