Discuss Meter Tails 16mm 0r 25mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
quite right haj, exact wording isThanks guys i quoted OSG it says SHOULD be 25mm not must be 25mm he says leave them alone i think change them.
hi i assume that it was a house you went to so has to be 25mm .also double insulated hope this helps.Talking with a collegue today regarding meter tails.I went to look at a c/u change 80A main head on 16mm Tails i said should be 25mm but he said 16mm was ok 25mm for 100A main head. Whats the word out there with you good men ?
Cheers
Just do it.Pull the fuse.Who says there was a seal on the cut out anywayDo you get leb in to pull fuse or are we aloud to disconnect from there meter
Reply to Meter Tails 16mm 0r 25mm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
