Discuss Move Outlet in Bathroom with Short Cable in the UK Electrical Forum area at ElectriciansForums.net
snoopede
I am moving an outlet in my bathroom. The original outlet is where we would like to put a vanity mirror. These outlets are located above the vanity. The faucet is about 6 inches to the right of these photos.
The cable comes from above and is not long enough to reach the new preferred outlet location. I would like to extend the cable without putting in an entirely new one. I have a couple of questions:
->Can I connect another foot of cable in the junction box using wire nuts and put a plate over it?
->Do I need to use a metal junction box or can I use a blue plastic one here?
->Is there a better way to accomplish what I'm trying to do?
Above you can see the current location of the outlet / junction box.
The red rectangle above represents where I would like to move the outlet. I also want to rotate it horizontally.
personally. I'd pull yhe cable back into the attic, joint a suitable length of cable to it, in a box with wagos or wire nuts, cut a new hole in ceiling, then reroute to come straight down the wall, chased in , to the new location.
OK the code says (in the US anyway) that anything entering and leaving a box or other device must be accessible. Look in "Definitions" for what the NEC deems accessible. So if I understand correctly you want to splice a foot of wire in the box, put a cover on it and then render it inaccessible by covering it all up with the new mirror? Can't do that legally. Put in a new circuit. Pull the old wire back to the attic as suggested above, (or abandon it) properly mount a box, make your splice and then run the new section of wire to where you want to relocate the outlet. Hope this helps.
Yes what you are wanting to do is legal and if I was you I would use the blue plastic boxes. As stated above you need to install a box in your attic and use enough cable to go from box to box. All splices have to be accessible so you can’t float it in the wall and it needs to be secure
Reply to Move Outlet in Bathroom with Short Cable in the UK Electrical Forum area at ElectriciansForums.net
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
