Discuss Moved a BT master socket in the UK Electrical Forum area at ElectriciansForums.net
My experience of Open Reach engineers is that if the job was done properly (using BT type cable and crimps or an IDC connector plate) they are quite happy. Modern BT Master Sockets have an internal connector where you are allowed to extend the line to other sockets. They now omit the transorb in Master Sockets which was there to limit high voltages from lightning strikes as "we had to replace far too many"!!! - also because it was limiting broad-band speeds due to its capacitance - so it is now up to customers to unplug or otherwise protect their phones and routers - this applies mostly to areas with overhead telephone wires. Few people know about this.
What they are not happy about - and neither would any of us be (!) - is where they are called out to a fault that was effectively created by someone else (i.e. not a BT engineer). Why should BT/Open Reach cover the cost of sorting a problem that was not created by them? There are lots of really crappy DIY changes out there which is why they ended up with such a strict charging policy. I suspect a decent job done properly by a skilled electrician would not be a problem. You do need to use BT type cable and accessories, though (not CAT5 !).
Moved dozens of BT masters over the years, usually to just inside the loft hatch, prior to full refurb jobs, with never a murmur from Openreach or their predecessors.
On one occasion, when I tested the line afterwards, I found I couldn't disconnect from the person (my wife at home) that I called. As we stayed on the line, more and more subscribers on the thankfully fairly small local exchange started appearing on the line, all finding that they couldn't leave either. Hotel California springs to mind.
I quietly replaced my handset and went on my way.
On the subject of moving electricity meters, mentioned earlier in this thread, I once not only removed a meter, but the service head, the board it was mounted on, and the complete service cable, right back to the external pole it was spured off, coiled the cable up neatly, put the whole thing in a large cardboard box, and put it in a safe place.
Unfortunately, I wasn't on site the day the meter reader came calling, and missed all the ensuing fun when this cardboard box was presented to him. Apparently he went absolutely ape, jumping up and down, shouting his head off, and promising to have the whole lot of us jailed for at least ten years, before storming off.
There's more to this story, both before and after, but needless to say, we never heard a thing from the REC.
Well .............. just to add to the amusement ....... the last 2 refurbs I have dealt with both needed the BT master moved and extended.
In both cases the customers organised it and paid for it
In both cases the BT engineer came along did the work plus left me with a large coil of cable so I could place the BT master where ever I wanted ........
So after they "installed it", leaving you to properly finish it?
That sounds similar to BT over here, last couple of new builds they have left it strewn across the floor and said get your spark to put it where you want it.
Sky installers can be rough and lazy, but BT installers seem to take the biscuit.
Check out the BT site support pages. The diagram they provide illustrates their responsibility for the service cable is ONLY to the boundary of your property. Therefore the cable within your boundary is YOUR responsibility as is the condition of the wiring and equipment. Your contractual obligation is to ensure that these are appropriately maintained, repaired and connected. DIY.
Had a couple of BT engineers out to check my connection as I have really poor BB speed. Engineers were fine but due to my location the BB speed is still s***e despite me paying top rates for service. It’s BT customer services that I can’t stand, takes ages to get anywhere.
I’ve now had to move my main incoming box due to building extension on house. Original connection joint on overhead line got bashed off by scaffolding. Currently lashed up with a Wago box. Works the same as before ....just about fast enough for my boy to play COD :rolleyes:
Reply to Moved a BT master socket in the UK Electrical Forum area at ElectriciansForums.net
Hi I’m wondering if anyone could help me I basically moved into a rental property February this year I’ve been unable to get internet I’ve had...
Has anyone had encounters with rogue landlords? I will tell my short story (and keep it as short as possible) I had a call a few weeks back from...
7K
