Discuss Multi point BT cable connection in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
ok, I slipped up when refurbishing our house and now need to connect 4 Bt cables together , in the loft.
What is the best type of JB to use?
@ Strima. what's wrong with jelly crimps. BT use them all the time/
Never seen jelly crimps connect 4 cables together, only ever seen 2 way and 3 way versions, do 4 way exist?
need to bear in mind weez up here in the impoverished North. no post collection after 4 p.m.fridays,pony express should deliver before xmas, if we don't want to drink and drive, then we must leave the pub @ 5 pm as that's the last bus of the day. seen one at 7 pm one evening. it was broke down awaiting the tow truck. not much point in calling the AA or RAC, they've not been trained on steam engines.
but should you use red/black tape or brown/blue.
Reply to Multi point BT cable connection in the UK Electrical Forum area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
htps://we.tl/t-JHXw09romZ quick share to photo Hi there. I am trying to convert previous cable network cat5e installed when had non fibre in 2015...
I have had my kitchen rewired ready for a new kitchen. I was originally going to have a gas cooker so a 3 pin 13a socket was left on the end of...
Hi all, as in the picture, when connecting a 230V cable to a db like this, is there a legal requirement to install external RCD unit? Also, if the...
