Discuss Neff Hob Fault in the UK Electrical Forum area at ElectriciansForums.net
L
Litttle Shonet
Had a fault with our hob: Only two rings work, others work when hob first switched on then go off shortly after. So called warranty company. When 'engineer' arrived and looked at it, he said the pans we were using were warped!!! I didn't tell him what I did for a living and let him tell me what he wanted. Plus the same pans work on the two rings that work all the time.
I think the fault is something to do with the control panel. Anyone else come across this fault or had dealings with bulls**ters.
last week was called out to a well known make of range cooker. authorised service engineer had repaired it some months ago , charged £65 for a thermal overload,(which had failed again). + £70 call-out. all + VAT.
Did you ever get the answer to the fault above I have the same fault of n the NEFF T58FD20X0.
Reply to Neff Hob Fault in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hello, Last year I had some electrical work completed in my house (New CU, SWA for garage, downlights) I informed the electrician that I will be...
Slightly strange one this, replaced a few socket fronts in a dining room today, all wiring original but new plasterboard on a studded wall. Its a...
