Discuss New Supply from DNO in the UK Electrical Forum area at ElectriciansForums.net
M
mort2376
Has anyone had dealings with ENWL regarding new supplies ?
A customer has asked me to quote for splitting his house in 2 ( 2 20KVA single phase supplies ) and a new supply to his shop located on the same property ( 1 60KVA three Phase Supply )
ENWL have agreed to install a 100 KVA supply to a stand alone building just on the edge of his property which will be split to the requirements above.
In their specification they have stated they require 117m red ducts installing having searched about 117mm duct is the solid 3m length ducting and costs the earth compared to the 110mm coiled ducting.
Can I just install the 117 solid ducting for their incoming cable into the mains building and then use the coil ducting for the customers side of the installation ?
I am worried about their threats to not install if all is not to specification, but their specification is very unclear.
Any help advice would be greatly appreciated.
Maybe it would be best to discuss your query with them! :smile:
Reply to New Supply from DNO in the UK Electrical Forum area at ElectriciansForums.net
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
Hi - first-time post from a complete novice. I want to install a 24kw electric boiler on my property but that size requires Phase 3 supply...
My customer has had a completely new supply installed to his garage. The DNO has not put a fuse in the cut out though. I'm guessing he needs to...
Laying ducting and hockey stick as preparation for new 3-phase supply which will be installed after front drive is done. How is the hockey stick...
5K
