Discuss Newbie, non-electrician looking for advice in the UK Electrical Forum area at ElectriciansForums.net
Samnotts
Hi folks,
Hi everyone! I'm Sam and will be owning my first home in the South West soon if the ongoing purchase goes through successfully. Its a 3 bed semi detached built in the 1970s and the current owner is a lovely lady who has lived in it since new but hasn't renewed or changed much since then. I am hoping to get advice on modernising the electricals and better still finding someone on this platform who is based in the Bristol area and can give me a quote to do the job when I have the keys
I have learnt a lot already from reading previous posts and look forward to learning more!
Cheers
If it’s mid/late 70s build, you should find its all pvc/pvc wiring.
the fact its lived in by one careful owner and not been messed about with too much is good. The less bodged diy wiring the better.
my best advice would probably be an eicr and then get quotes for the work you want doing. Chances are you will need a new fuse box (consumer unit) and probably want some additional sockets and mains smoke alarms etc
That's great to hear! I'm hoping to get away without a full rewire as money is tight. The EICR will show what needs doing as you say. Cheers
Hi folks,
Cheers
Where in the Bristol area are you Mate? from Bath originally myself. Twerton to be exact.
Oh wow. I viewed a house in Twerton but was outbid on that one. Lovely area.
I'm currently based in Leicester. The house is in North Bristol, Filton. I'm moving for work. The usual advise is to rent for a while in a new arear before buying. But after renting for over a decade I think I've paid my dues and didn't want to fall into the rent trap again.
moved to N/ton now due to work before I retired, wanted to go back bur\t prices to much so staying put
House prices are completely mad, right now!
Tell me about it , my next door neighbour moved in just under 2 years ago. He paid ÂŁ380,000, decorated the house , put new carpets in and just sold for ÂŁ565,000 after a round of sealed bids ( was on the market for offers over ÂŁ500,000)
these kind of prices increases are not sustainable
That's just insane ??. It's stories like this which made me want to buy right away instead of renting for a while. The possibility of ever owning a house just seemed more distant the longer I waited. This is simply unsustainable
As above, get an EICR done but don't go for the cheapest as it will take about half a day or more to do properly, so consider how much skilled time you are buying. You can post the results here with any personal identification removes (you, address, who did it, etc) for any comments/feedback.
From what you said, probably all you would be looking at is a new consumer unit (CU = fuse box) to have RCD additional protection against shock (and to a lesser degree fire) as well as the convenience of easy resetting instead of having to correctly change fuse wire.
If you plan on decorating then think long and hard about any electrical changes you might want, such as more sockets (probably lacking from a 70s install) or anything fancy in the way of lights, etc. Now is the time to do it!
At the very least you might want all new sockets/switches depending on the condition and appearance, and then you might have any single sockets changed for doubles, etc.
It'll be all PVC if '70s, but early 70's raises the possibility of the dreaded green goo.
If it's OK on this front, the main problem will likely be lack of wiring, rather than its condition. There's as many lights and sockets in the average new kitchen than there was in a whole house in the '70s.
Thanks, noted! I'm hoping to modernise and 'future proof' it best as can on not a very great budget. My current rental property has got the one double socket in the bedrooms and it's a right pain managing that.
Reply to Newbie, non-electrician looking for advice in the UK Electrical Forum area at ElectriciansForums.net
Hi all, been a user of the forum for many years now as a complete lurker and throughout this time I would firstly like to thanks everyone for...
As per the title, I have not been in a position that I've needed to find work through an agency since the early 90's. Anything tricks they may...
hi im 32 and currently a decorator but fed up of it now so looking at being a sparkie. ive got a few mates who are sparkies themselves and been...
Hi all! I am new to this forum and have signed up because I am looking for 10 handymen/electricians in the area of London. The job is fairly...
Hi all Firstly, I'm not an electrician but have found these forums extremely helpful reading over the last couple of weeks due to a running...
