OP
guest119
Is the central heating (suspect pump?) on the ring circuit?
Boydy
Boydy
Discuss Nightmare fault!! in the UK Electrical Forum area at ElectriciansForums.net
This record is wearing thin.
Boydy
But would you have tested all the neutrals with each other for continuity to see if there was a borrowed neutral UK?
ps.. before the change.
Neutral to earth fault on up sockets.
exposed neutral conductor touching back box!
As it happens, I do. It was ever since discovering a borrowed neutral on a stair light on a board I fitted a shower to.
I try to eliminate every possible problem before I change a board.
Reply to Nightmare fault!! in the UK Electrical Forum area at ElectriciansForums.net
