F
freedomrun
I'm looking at a CU swap in a Flat above a shop. The MET in the Flat has no Bonding to the Gas or Water present, i think it could well be connected to the services in the shop below the flat. I know i should i run new bonding up from the property below. I've been looking...... but where in the regs do i find the exact regs relating to properties containing multiple dwellings, each with a seperate MET and connection to the Gas and water services required. Many thanks for direction on this.
