Discuss OLD SWA Cabling and earth sizes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bigpaul
Hi,
Is any body aware when LSOH SWA cable to BS6724 first introduced to the UK? Also, is anybody aware of the copper sizes that were available for the bare copper conductors used to bond installations in the circa 1960's? I am coding a PIR report and for my own knowledge I would like to know what size copper was typically used back then.
Paul
BS6724 is listed as1997 updated 2007.
bare earth wire for bonding in 1960's was usually 7/.029 = 2.5mm2. main earth often 7/.044 = 4mm2. if memory serves.
There was no bonding in the 60`s but as I started my apprenticeship in 62 I can remember most of the sizes,
3/029 = 1.0mm used for earthing counduits especially tin whistle
3/036 = 1.5mm sometimes used for obtaining an earth from the water main, yes it was allowed then!
7/029 = 2.5mm bare earth wire run with twin 7/029 cables on power circuits and commonly used for running to an earth electrode from an ELCB (voltage frame connection)
7/036 in between 2.5 and 4.00mm
7/044 = 4.0mm
7/052 = 4.0mm
7/064 = 6.00
hope this helps
Reply to OLD SWA Cabling and earth sizes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
I'm in Azerbaijan, and in our company store we have a number of drums of cable, all upwards of 5 years old and basically unsaleable. We're looking...
Those week I have mostly been fitting 20 x 10W flood lights on the sloping edge of a converted mill ceiling, nothing is straight, nothing level...
Hi guys, This has probably been asked many times before but just want to know others opinions. Just done an EICR and have found (or not found) any...
4K
Christmas crew, hope you all enjoying yourselfs. Ive been reading a thread on another forum about parallel paths. In certain installations, namely...
5K
