OP
lawsonium
Des 56: haha, very good. Thanks for the advice though, will check it out.
Steve1412: not sure what that was?
pushrod: interesting... Does that mean that for the short term I can protect the spur with two sockets by changing one of them for a fused unit? Thus having the same protection effect as a 13 A fused multi-socket-bar-thingy?
What kind of unit would I be looking for from my local sparks supplies? I'm quite happy replacing electrical equipment at that level... not planning on tackling the CU change out (before anyone starts leaping on me).
telectrix: that's the sort of thing I'm talking about, have used them in the past when living in a flat. However, as was pointed out, probably have 13 A protection themselves anyway.
One more thing if I may chaps. Something else I have come across that I wouldn't have thought a good idea. Some of the cabling appears to be threaded up through the external wall cavity. So far I'm sure the lighting cables, the main ring and two (now unused) storage heater cables have been threaded through to get them from downstairs to upstairs.
The house has rendered brick walls so there is no place to trace cables easily. All this work had to have been carried about by a council contractor.
What are your thoughts on this?
The bit I am amazed about is that the house has recently had the wall ties replaced and cavity wall insulation injected into it. Seems only pure chance that none of the cables have been hit!
Thanks again,
Matt.
Thanks again,
Matt.
