Discuss one earth sleeving doing both cpc's behind a socket. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
it is bad practice you wouldn't do it in a fuse box as it would be extremely frustrating for testing.
another example is ceiling roses we have done it there saves alot of time (5secs) you know what i mean.
its not against any regs but just bad practice..
Just the other day I saw what was almost the opposite in a CU, where the cooker radials CPC went to the CPC bar via several earth sleevings! Presumably the installer didn't have any with the appropriate diameter to hand! Equally bad practice!
Worse than that, impossible to distribute the prospective fault current evenly, there really are some idiots around!
It really bugs me especially if the cpc's are twisted also.
Sent from my iPhone using Tapatalk
Absolutely.
Fortunately they've just given me the go ahead to fit a new CU full of RCBO's so it'll be on my list to do properly.
i avoid twisting them together as i think in the event of a fault arching may occur between cpcs as there is not a proper termination...
also very annoying when fault finding
totally agree wiv all comments,1970s the electricians always did it that way,1 green sleeving 4 all earths,working amongst them they still carried on doing it until retirement day,even though they were told not 2,also bending over cables for termination,they still didnt get that either,i could go on abit here,thankfully a new breed is let loose,& 20 years on someone will still be critising the way we r doin it !!Ta ra bab
Reply to one earth sleeving doing both cpc's behind a socket. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
I’d appreciate your professional views on this question, as I’ve had 2 of the associated electrical bodies quizzed on this.!!!! ON changing/up...
Every time i go to do this, even with correctly fitting sleeving, it seems to be a right **********")£"$$* of a job getting all three in snugly...
