Discuss Outside Light with PIR stays on permanently in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
I’ve replaced a porch light today it’s fed by a fused spur. But when you turn the fused spur on the light stays on permanently.
I can upload pictures of the light and also the fused spur.
switch the f/switch off and stat again ,or disconnect the pir and see if the feed is on live by switching off or on .
In other words it may be stuck in a fancy permanent on mode
..soon cured by Turning off the supply ,
Waiting 20 sec , then back on in a clean single action.
(as jiggling the power on and off multiple times is how you get into override mode )
---Or turn it off and look for signs of water--(then look for bin)
I could not explain any better Stanley .
th
Reply to Outside Light with PIR stays on permanently in the UK Electrical Forum area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi all, Thank you in advance... So I had an electrician put in some FCUs on spurs to a couple of outside lights.. this one was in readiness to...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
