Discuss Oven and hob. Who's right? in the DIY Electrical Advice area at ElectriciansForums.net
Hugely grateful for any advice. As part of our kitchen refit, we want to install an induction hob which is 32 amps. We have a 45 fused spur for oven and hob. Our oven is 14 amps. The induction hob takes us to 46 amps, 1 amp over. First electrician says we either need to rewire the kitchen to accommodate new hob or replace the oven with 13 amp version and use the existing fused spur.
The second electrician says we can use the 45 amp fused spur, because we'd never in practice use 46 amps unless we had all four hobs on max while doing a pyrolytic clean with the oven (very unlikely) and would be happy to sign off the work. Who's right?
Reply to Oven and hob. Who's right? in the DIY Electrical Advice area at ElectriciansForums.net
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hi, I've searched these forums and have found quite a bit of good information, but not specifically to my query. My house is about 9 years old...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
