Discuss Pancake , fancake , duplex , nail on , rough in in the UK Electrical Forum area at ElectriciansForums.net
ultimately it will be exactly the same here or anywhere , you will have good installation electricians & rubbish electricians with shonky standarea.
if the code in the U.S is followed to the letter their istallions will be perfectly adequate.
they have some interesting codes of practice , like how many cables you can put in a box to how many clips you have to use etc
The problem is more subtle than that. They don't have 'one code', they have several different ones that will vary State by State, even county by county. Generally speaking they don't test anywhere near to the levels that we do (aka the 'bang test' - if doesn't go bang when turned on it's OK). And more-so than that....... house construction is different and much much younger than ours. As I often tease my American friends and colleagues - my house is older than your country!
Their philosophy is if you build / install something to code then it doesn’t require testing. Which is an interesting practice.
they dint have millions of house fires and homeown blowing themselves up each month so the method works ok to a point...:)
i question some of their methods like twisting sold cores to make joints etc but they have recently discovered Wagos so the fire nut is slowly falling out of favour
It is, I'll concede, curious that the stats for electrical fires for both nations are roughly the same - around 7-8% caused by electrical distribution faults
We could probably all learn a bit from each other’s installation practices , I quite like their big deep boxes , thin walled conduit / metal flex conduit and massive fuse boards ...
Another need for AFDDs in america is the extensive use of aluminium cable in houses, not easy to make a sound joint on small aluminium cables.
Reply to Pancake , fancake , duplex , nail on , rough in in the UK Electrical Forum area at ElectriciansForums.net
I had a job recently where myself and an apprentice had to gland and terminate a 50mm SWA cable in a panel. I put the locknut in a vice and filed...
7K
Thought it'd be interesting to see for those who are self employed. Work for themselves. As I'm doing level 2 . Nice to see how others already in...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
